I have the some problem with umbraco.What that, I am forget my password of umbraco admin page for my website.How cam i get back that password.Please help me everyone..
If you have access to the database then you can reset the password by following these steps - But ONLY do it if you know what you're doing :)
1: In the web.config of the Umbraco application search for "hashed". It should give you 2 hits concerning passwords for users and members. Change both from "hashed" to "clear". This make Umbraco store the password as clear text in the database.
2: Go the user table in the database. In the password column you'll see your current password...in a hashed format. So change the password in this column to one you can remember in clear text.
3: Login to Umbraco and stay logged in while you do step 4
4: Change the web.config back to using "hashed" instead of "clear", since "clear" is not recommended due to security reasons.
5: When the web.config is changed back to storing password in a hashed format - in Umbraco you go to the users section and change your password once again so the password is being hashed again.
Forget My Password For Umbraco Admin Site
Hi Every One!
Good Day.
thank & best regard
Ko Phyo
Hi Ko and welcome to our :)
I hope this makes sense!
Hi Ko,
I will like to add another way of doing this (A shorter way). Jan´s post is a great step by step guide,
1: Find the user table in database. Change th string in the password column to bnWxWyFdCueCcKrqniYK9iAS+7E=
This string bnWxWyFdCueCcKrqniYK9iAS+7E= is the hashed value for the password default.
When you have done that you should be able to login with your username and in the password field you type default.
2: After you´re logged into the Umbraco office go the users section and change your password, to the password that you want.
As I said this is a short version of Jan´s great great guide.
If you want an SQL script you could execute this script on the database, and it should set the admin password to default
Remember to change the userLogin if yours is not admin if you choose to use the SQL script.
As Jan says be careful you're dealing with the database.
/Dennis
Just had to battle this issue and it turned out that the admin record had userNoConsole set to 1.
So the fix was to reset this along with the password
The weird thing is, as far as I can tell only the Admin account has access to the Admin account settings to make that fatal change.
Thanks Jan and Dennis - saved me again!!
Tony
I couldn't manage to reset password on umbraco 6.2.5 :(
Actually i remember the password, but i can't login after installation and working over site for hours.
Any ideas?
