  • vuser1 1 post 21 karma points
    Oct 26, 2009 @ 21:40
    vuser1
    RichTextEditor features - font color, text size
    It looks like TinyMCE included in Umbarco does not support font color and text size. Instead, I have to create CSS, populate "Styles" combobox and use CSS styles for articles. Is it true? Is there a way to activate text color&size in text editor?
  • Chris Koiak 700 posts 2626 karma points
    Oct 27, 2009 @ 14:40
    Chris Koiak
    2
    This is correct and intended.
    It allows you/designer to limit what is available for your clients to do. It also simplifies the styling options for your client making it easier and quicker for them to add custom styles their pages.
    Howver, you can probably re-enable these features in config/tinyMceConfig.config.
  • Gary 20 posts 44 karma points
    Nov 02, 2009 @ 23:58
    Gary
    3
    I figured out the text colour. I'm sure the size is something similar.
    In config/tinyMceConfig.config add the following to the commands node
          <command>
              <umbracoAlias>mceForeColor</umbracoAlias>
              <icon>images/editor/forecolor.gif</icon>
              <tinyMceCommand value="" userInterface="true" frontendCommand="forecolor">forecolor</tinyMceCommand>
              <priority>75</priority>
          </command>
    Not sure what the umbracoAlias is used for but the rest is pretty straight forward. change the priority to change where the button shows in the toolbar (should be unique but haven't tested)
    tinyMCE uses spans to change the colour and by default the config in umbraco disables styles in spans so you need to modify the <validElements> node. basically look for:
    -span[class|align]
    and change it to
    -span[class|align|style]
    Then touch web.config or manually restart the website to read the new config. Log into the umbraco and go to Developer --> Data types --> Richtext editor and you should see the icon for the colour palette. You'll need to tick it to be shown in the content editor.
    I think that's all I needed to do!
  • Shulamit Umansky 3 posts 27 karma points
    Nov 14, 2009 @ 18:06
    Shulamit Umansky
    4
    Here is the code for font color and font size selectors:
    <command>
    <umbracoAlias>mcefontselect</umbracoAlias>
    <icon>images/editor/fontselect.png</icon>
    <tinyMceCommand value="" userInterface="true" frontendCommand="fontselect">fontselect</tinyMceCommand>
    <priority>17</priority>
    </command>
    <command>
    <umbracoAlias>mcefontsizeselect</umbracoAlias>
    <icon>images/editor/fontsizeselect.png</icon>
    <tinyMceCommand value="" userInterface="true" frontendCommand="fontsizeselect">fontsizeselect</tinyMceCommand>
    <priority>18</priority>
    </command>
    However, you have to make the icons for these two buttons yourself (fontselect.png and forntsizeselect.png) in order for them to be displayed nicely in Data Types->RichText Editor configuation page.
  • Bohdan 3 posts 23 karma points
    Feb 07, 2011 @ 15:31
    Bohdan
    thanks - give more xml snippets for newbies like me
  • Douglas Ludlow 210 posts 366 karma points
    Feb 11, 2012 @ 00:32
    Douglas Ludlow
    Here's a few more. Took me a bit to stumble around and find them. I'm really loving the customConfig section. Bravo, to whomever came up  with the concept on that.
    To remove the "More Colors" link in the text color menu, you have to add the following to the section of the tinyMceConfig.config:
    <config key="theme_umbraco_more_colors">false</config>
    (Reference: http://www.tinymce.com/wiki.php/Configuration:theme_advanced_more_colors)
    Then to limit the colors that are available to the user:
    <config key="theme_umbraco_text_colors">000000,0079E3,FF0033</config>
    This will limit it to only 3 colors. Of course you can add as many as you like.
    (Reference: http://www.tinymce.com/wiki.php/Configuration:theme_advanced_text_colors)
  • Dane Garcia 6 posts 56 karma points
    Feb 13, 2013 @ 20:36
    Dane Garcia
    I've tried to add the suggested code about to no avail, has Umbraco fully disabled this in a newer release? I add the exact code and nothing changes, I look in "Developer" > "Data Types" > "Richtext editor" > "Buttons" I don't see the new options. I also don't see them in tinyMCE.
    Feb 13, 2013 @ 22:02
    Hi Dane
    To see the new buttons after you have added some of the config elements above, make sure that you recycle your app pool - you can simply just touch the web.config file.
    Then go back to the developers section and load your rich text editor data type again. Now you should see the new options that can be activated in the RTE.
    Hope this helps.
    Feb 14, 2013 @ 22:18
    Douglas Ludlow
    @Jan is right. Here's a little walkthrough that may help: https://blunderings.wordpress.com/2012/02/21/using-the-tinymce-color-picker-in-umbraco/
  • prinzie 13 posts 42 karma points
    Jan 16, 2014 @ 11:50
    prinzie
    Anyone know where you can customize those font sizes?
    I found the file: editor_template_src.js in the dictionary:
    Umbraco_Client\Tinymce3\Themes\Advanced
    Umbraco_Client\Tinymce3\Themes\Simple
    Umbraco_Client\Tinymce3\Themes\Umbraco
    But none of them seem to be ‘active’ (yes I have recycled the app pool )
  • Anders Schmidt 76 posts 207 karma points
    Apr 28, 2014 @ 12:50
    Anders Schmidt
    Is there any update on this one. Using Umbraco 7.
    Text colors added and working. But I would like to select colors to pick.
    My code:
        <customConfig>
            <!--  <config key="myKey">mySetting</config>-->
            <config key="entity_encoding">raw</config>
            <config key="spellchecker_rpc_url">GoogleSpellChecker.ashx</config>
        </customConfig>
    Apr 28, 2014 @ 12:57
    Hi Anders
    You Probably need to add
    in your tinymceconfig.config file as well.
    Remember to recycle the app pool (simply touch web.config) and see if the change is taking effect.
    Hope this helps.
    Apr 28, 2014 @ 12:58
    argh, the editor ate my code so it's missing in my first post.
    Here it is!
    <plugin loadOnFrontend="true">template</plugin>
    Apr 28, 2014 @ 13:20
    Anders Schmidt
    Hi Jan.
    Thanks for this quicky. It did not help me. I have added with.
    My plugins:
           <plugin loadOnFrontend="true">template</plugin> <plugin loadOnFrontend="true">code</plugin> <plugin loadOnFrontend="true">paste</plugin> <plugin loadOnFrontend="true">umbracolink</plugin> <plugin loadOnFrontend="true">anchor</plugin> <plugin loadOnFrontend="true">charmap</plugin> <plugin loadOnFrontend="true">table</plugin> <plugin loadOnFrontend="true">textcolor</plugin> <plugin loadOnFrontend="true">lists</plugin>
    I have added the textcolor also. The color btn is working. Only thing is to modify the colors inside btn.
  • André Nøbbe Christiansen 10 posts 71 karma points
    Jun 11, 2014 @ 20:10
    I'm having the same problem as you Anders. Did you ever figured out any solution?
    Jun 11, 2014 @ 21:53
    Anders Schmidt
    @Andre, No sorry I have never found solution on costume colors...
  • Kristoffer Eriksen 185 posts 465 karma points
    Jun 27, 2014 @ 12:34
    Kristoffer Eriksen
    I've succeded with this thread
    http://our.umbraco.org/forum/umbraco-7/using-umbraco-7/49556-TinyMCE-and-forecolor-%28text-color-picker%29
    Didn't need to include
    <command>
            <priority>27</priority>
          </command>
  • Søren H. Pedersen 15 posts 65 karma points
    Aug 11, 2014 @ 12:33
    Søren H. Pedersen
    Hello there
    I was in need of a font size editor and found this lovely post, and It works like charm.
    However, the icons I've created is not showing up at all, even though I've "touched" the webconfig file and reloaded the side.
    <command>
        <icon>images/editor/fontsizeselect.gif</icon>
    </command>
    Any ideas how to fix this?
    Kind Regards Søren
