I've run into an issue with the umbracoUseDirectoryUrls which I hope someone can shed some light on :)
I have a 4.0.2.1 site with a products directory:
HOME- Products-- Product1
I set an umbracoURLAlias for Product1 so you can get to it directly eg
website/product1.aspx will bring up website/products/product1.aspx
This works with no issues.
I've been asked if it's possible to have it extensionless so I've enabled umbracoUseDirectoryUrls as described here: http://our.umbraco.org/wiki/install-and-setup/setting-up-umbraco-for-friendly-urls
This works fine on a test server (win2003).
website/product1 ---> website/products/product1.aspx
However on the production server (also win2003) something odd happens:
website/product1 ---> website/products_product1.asp
The servers look to be set up the same but I'm not sure why the production is defaulting to ".asp" and why the directory "/" is being made into "_"
Any ideas?
Thanks in advance!
Oops, solved my problem.
Someone had installed an ISAPI rewriter on the production machine.
Can someone delete this please! :)
umbracoUseDirectoryUrls with URLAlias Problem
Any ideas?
Thanks in advance!
