Developing my first Umbroca site using version 7 (razor templates). Things have been going pretty well so far, but I'm running into a strange issue in the backoffice area. Basically, I want to restrict certain users to only accessing a certain document and its children in the treenode. The setup seems to work well, but whenever I click on an item in the Treenode the backoffice page refreshes and the user looses their currently expanded items. Not a huge issue, but pretty annoying in my opinion. I check my chrome console and didn't have any javascript errors. Anybody have any idea what's going on here or should I open a bug report on the tracker? Please let me know if there is anything else I can include to help.
It's good to hear you're enjoying yourself with developing in Umbraco.
I would suggest you check the issue tracker at http://issues.umbraco.org/issues to see if others have created an issue for this. If so add your comments if you can provide more details that can help figure out how the bug could be fixed and vote for the reported issue.
Otherwise please create the bug report so others can go and vote it up if they encounter the same issue. If you have the skills you could perhaps even contribute a core fix and make a pull request? :)
Sorry it's taken me so long to get back to you! I searched through the tracker and couldn't find any similar issues so I've added an issue to the bug tracker here. Thanks for your suggestions.
Unfortunately upgrading is not really an option in this my current situation. Also, it looks like some updates have been made to the bug report that indicate that this affects 7.1.2. Thank you for the suggestion though.
I'm not sure about 7.1.4? It doesn't look like it's listed on the bug report so maybe it's been fixed? Unfortunately I can't really upgrade the site to the newer version at this point but when I get a chance I'll download 7.1.4 and see if it's been resolved.
Treenode Refresh (Possible Bug)
Hi All,
Treenode View:
User Acount Type:
User Account:
Hi Nathan and welcome to our! :)
Hope this helps.
Hi Jan,
nathan
Hi Nathan
Perhaps your issue can be fixed now by upgrading to 7.1.2? I suppose the installation you're seeing the issue on is 7.0.x ?
Cheers, Jan
Hi Jan,
nathan
Hi Nathan
How about 7.1.4 then? :)
Hi Jan,
nathan
