  • Hardy Wang 91 posts 112 karma points
    Mar 21, 2014 @ 15:50
    Hardy Wang
    Public Access (form auth) and 401 code
    I set some node to request role based access credential, and I built a login page to accompany with the settings.
    My question is if login fails is there a way I can simply throw 401 code from that login page I built without displaying anything or use setting in web.config <forms name="yourAuthCookie" loginUrl="login.aspx" protection="All" path="/" />
    Currently if my code in my login page is
    if (this.Authenticate(username, password))
        Response.Redirect(contentPageUrl, false);
    else
        Response.StatusCode = 401;
        Response.End();
    private bool Authenticate(string username, string password)
        if (Membership.ValidateUser(username, password))
            FormsAuthentication.SetAuthCookie(username, false);
            return true;
        return false;
    Then Umbraco tries to use /login.aspx as set in config file
    Or if my code is
    It just show the same custom login page again.
