Hi, i have an umbraco solution where there are to websites running (2 root nodes). In the future we have to create a lot of new websites. These new websites i want to place as new root nodes in same solution, but does anyone know have many root nodes you can have without getting poor performance in the umbraco backend.
We need about 200 new websites, but there might be coming more in the future.
Umbraco can have unlimited root nodes - I think that the amount of nodes in an Umbraco installation is up to 200.000 nodes before you should be able to see some performance drops in the backoffice...If I remember this stuff correctly.
But I think that it also depends on custom API integrations etc. since 3rd party code could slow it down depending on what it does etc. - And it can probably also slow down for other reasons, where optimizing the database adding indexes can improve backoffice performance.
How many root nodes in umbraco?
By the way. Its an umbraco 6.0.6 version.
Hi Anne
I hope this answer is usefull to you.
