Is there any way to do CollapsiblePanel in Umbraco?
I need it exactly the same way as in AjacControlToolkit
http://www.ajaxcontroltoolkit.com/CollapsiblePanel/CollapsiblePanel.aspx
If you want to use the ajax control toolkit in Umbraco you can do excatly this.
Just make sure you register the toolkit at the top of the page i.e
<%@ Register Assembly="AjaxControlToolkit" Namespace="AjaxControlToolkit" TagPrefix="ajaxToolkit"%>
and add a scriptmanager i.e
<asp:scriptmanager id="sm1" runat="server" />
Alternatively there are lots of jQuery alternatives which you could google.
Expand/Collapse Menu Item
