  • Anders Dahl Tollestrup 73 posts 52 karma points
    Oct 29, 2009 @ 11:02
    Missing document links
    After moving my umbraco sites from local server to SeekDotNet hosting I got problems in publishing documents on my umbraco sites. The documents gets published and is shown right (without the golden star) in the treeview but has no document link and therefore isn't shown on the website
    Any clues ?
    SeekDotNet is running Windows 2008, IIS 7 and ASP.NET 2.0/3.5
    Cheers
    /Anders
  • Chris Koiak 700 posts 2626 karma points
    Oct 29, 2009 @ 14:43
    Chris Koiak
    I would think this is a permissions issue. Probably the /data/umbraco.config file is not getting updated.
    Try checking your permissions are all as described here http://umbraco.org/documentation/books/important-files-and-folder-structure/permissions
    Oct 29, 2009 @ 17:37
    Hi Chris
    Thanks for your help, but unfortunable it didn't solved the problem. NETWORK SERVICE has read/write acces to the entire website folder and child folders/files.
    /Anders
    Oct 29, 2009 @ 18:52
    Hmm, weird.
    A republish of the entire site seems to solve the problem - maybe in combination with permissions change as mentioned above.
    /Anders
    Oct 29, 2009 @ 19:59
    Chris Koiak
    Glad you got it fixed!
