I found this package for the Cookie laws: http://our.umbraco.org/projects/website-utilities/cogworks-cookie-directive
I think this is just what I need, but I just want to make sure.
On my website I only have Google Analytics, so this package is perhaps a bit overkill, but the only one I could find.
My question is: can I use this package when the only cookie I use is for Analytic?Can I delete all the dokuments ind the "Internal" folder?
Hi Kate,
Yes, you can use this package. I think you can delete all nodes in the "Internal" folder.
Hi Alex
Thanks. I will try it tomorrow :-)
cookie question
Hi Kate,
Hi Alex
