  • Jan Molbech 40 posts 126 karma points
    Apr 28, 2014 @ 09:54
    Jan Molbech
    Is it possible to alter default 'create member' template
    Is it possible to remove login name, password and email fields from the 'create member' template, or atleast make them 'not-mandatory'?
    Apr 28, 2014 @ 12:08
    Jeroen Breuer
    I once did this.
    In /umbraco/config/create/ui.xml search for initmember. It points to a usercontrol, but you can change to path to go to your own usercontrol. There you can control what fields need to be used. I copied the originial usercontrol from the source and changed that.
    Jeroen
