insert image > unchecking constrain proportions doesn't do anything
I've got some issues with the images i've inserted in content, I've found that unchecking "contrain proportions" doesn't do anything, proportions are still maintained...
Indeed you are right. There seems to be a line missing from the javascript function fired when the dimensions are changed.
You can get around that by opening the html pane and changing the height and width in there (also delete the rel="300,200" attribute). And I suggest submitting this as a bug on codeplex
