I just had my hosting provider, softsyshosting, install an SSL certificate on my Umbraco-powered site. Now all of a sudden when I try to, say, create a template in the backoffice I'm being hit with a >>Windows<< dialog box asking me for a username and password. I tried using the Umbraco password for the site, but, as expected, that didn't work. When I cancel out of the repeated credential prompts the Create Template dialog box gets filled up with an error message:
Server Error in Application "IMPROVEDSCHOOLFUNDING.COM"
Internet Information Services 7.0
Interestingly enough, the site appears to still be serving pages...which is really odd, because as I mentioned in a separate post just now I think I accidentally deleted all the templates. Although maybe the reason the template node turns up empty is related to this bizarre access problem. I've used FileZilla and confirmed that the template files themselves are still there.
1) The template files are all in the masterpages folder.
2) I've looked in the template table in SqlServer and the templates >>seem<< to be properly represented there, too.
But every time I click on the little triangle next to the Template node it givs me the "One moment please..." message and then...the triangle disappears and no templates appear.
Help with Weird Problem
Any help or leads would be appreciated.
- Mark
Some more information:
What the heck is going on??!??!
- Mark
Is this when using https:// ; or http:// or both?
Both. Although I never intended to use https, that just happened once by accident.
- Mark
