  • Claes Brandt 1 post 21 karma points
    Nov 05, 2009 @ 10:02
    Claes Brandt
    Umbraco and tinyMCE vs. Kaspersky Internet Security Suite 2010
    My umbraco websites have been running all fine so when Umbraco suddently had trouble displaying the tinyMCE popups (HTML editor, Image editor), I started searching for the reason. At first I thought it was something with Windows 7 or my browsers, but then I started disabling various components in Kaspersky. It turned out that the Anti-banner component in Kaspersky prevents Umbraco from displaying tinyMCE popups correctly. So I just disabled Kaspersky's Anti-banner component and installed AdBlockPlus in Firefox instead. Everything works fine in Umbraco now.
    I am sure Kaspersky will fix this in some release. Kaspersky is an excellent product and this is just a small issue that can be handled easily. I have not had any other problems with Kaspersky and would any day recommend it. I am running Kaspersky Internet Security Suite version 9.0.0.736.
  • Chris Houston 535 posts 980 karma points MVP admin c-trib
    Nov 05, 2009 @ 10:55
    Chris Houston
    Hi Claes,
    I also use Kaspersky, although I have recently upgraded my desktop and I have not yet installed it.. ( opps! ) anyway, I thought there was some way of setting up white list sites within Kaspersky?
    Best regards,
    Chris
