  • Jonas 10 posts 30 karma points
    Nov 06, 2009 @ 16:49
    Jonas
    Adding styles to TinyMCE
    I have a question about adding styles to the TinyMCE editor. I have read the guides and it says I have to activate the stylesheet I want to use and then right click and add styles somewhere... I have chosen which stylesheets I want to use, but where exactly do I have to right click? I have tried everywhere but I just can't seem to find a place to add styles!
    It is probably a stupid question, but I have been going round adn round in a circle for the last hours and am now stuck!
    Nov 06, 2009 @ 16:53
    Rich Green
    In the Umbraco UI, go to settings, then stylesheets, right click the style sheet and select 'Create'
    Rich
    Nov 06, 2009 @ 22:14
    Hi Jonas
    In the developer section you should go to the data type section and select the TinyMCE type. There you can select, the stylesheets you want to display on your document type.
    You can add styles in the stylesheet by going to the settings section and select "Stylesheets". There you can define your styles.
    Hope this helps.
