I just copied my files on my server, and everything is going well on the frontend... I'm trying to go into the admin site, and there surprise nothing is working. I can login, and then nothing anymore... On any panel I click, I only view the root elements. If I run the admin from my local machine with the connection to the production database and it's OK.
In the logging table I found such things : I already changed some read/writes permissions on the data and umbraco directories but no help. So any advice is welcome ?
At /umbraco/developer/packages/BrowseRepository.aspx?repoGuid=65194810-1f85-11dd-bd0b-0800200c9a66 (Referred by: http://localhost:1234/umbraco/TreeInit.aspx?app=developer): System.ObjectDisposedException: Cannot write to a closed TextWriter. at System.IO.__Error.WriterClosed() at System.IO.StreamWriter.Flush(Boolean flushStream, Boolean flushEncoder) at System.IO.StreamWriter.Flush() at umbraco.cms.businesslogic.packager.Settings.HasFileAccess(Exception& exp) at umbraco.presentation.developer.packages.BrowseRepository.Page_Load(Object sender, EventArgs e) at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at umbraco.BasePages.BasePage.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Euh I just noticed that the error is from my local thing... So I bet that there is no logging from the production server. But I can login on the admin so the DB is definitiely accessible.
Copying files may change permissions settings on any folder of the umbraco installation. Apparently, you've found the solution as re-applying permission settings is what's required.
Admin error
Ok, I had to reset the permissions on the bin directory.... Strange things happens there !!!
/Dirk
