Exception Details: System.ComponentModel.Win32Exception: The network path was not found
Source Error:
Stack Trace:
[Win32Exception (0x80004005): The network path was not found]
[SqlException (0x80131904): A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)]
System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, UInt32 waitForMultipleObjectsTimeout, Boolean allowCreate, Boolean onlyOneCheckConnection, DbConnectionOptions userOptions, DbConnectionInternal& connection) +414
System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal& connection) +78
System.Data.ProviderBase.DbConnectionFactory.TryGetConnection(DbConnection owningConnection, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal oldConnection, DbConnectionInternal& connection) +196
System.Data.ProviderBase.DbConnectionInternal.TryOpenConnectionInternal(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions) +146
System.Data.ProviderBase.DbConnectionClosed.TryOpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions) +16
System.Data.SqlClient.SqlConnection.TryOpenInner(TaskCompletionSource`1 retry) +94
System.Data.SqlClient.SqlConnection.TryOpen(TaskCompletionSource`1 retry) +110
System.Data.SqlClient.SqlConnection.Open() +96
Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteReader(String connectionString, CommandType commandType, String commandText, SqlParameter[] commandParameters) +60
umbraco.DataLayer.SqlHelpers.SqlServer.SqlServerHelper.ExecuteReader(String commandText, SqlParameter[] parameters) +37
umbraco.DataLayer.SqlHelper`1.ExecuteReader(String commandText, IParameter[] parameters) +81
[SqlHelperException: Umbraco Exception (DataLayer): SQL helper exception in ExecuteReader]
umbraco.DataLayer.SqlHelper`1.ExecuteReader(String commandText, IParameter[] parameters) +136
umbraco.cms.businesslogic.web.Domain.<GetDomains>b__0() +76
umbraco.cms.businesslogic.cache.Cache.GetCacheItem(String cacheKey, Object syncLock, CacheItemPriority priority, CacheItemRemovedCallback refreshAction, CacheDependency cacheDependency, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) +123
umbraco.cms.businesslogic.web.Domain.GetDomains() +173
umbraco.cms.businesslogic.web.Domain.GetDomain(String DomainName) +44
umbraco.requestHandler.CreateXPathQuery(String url, Boolean checkDomain) +227
umbraco.requestHandler..ctor(XmlDocument umbracoContent, String url) +546
umbraco.UmbracoDefault.Page_PreInit(Object sender, EventArgs e) +1084
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +51
System.EventHandler.Invoke(Object sender, EventArgs e) +0
System.Web.UI.Page.OnPreInit(EventArgs e) +9531286
System.Web.UI.Page.PerformPreInit() +31
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +335
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.18446
Umbraco Exception (DataLayer): SQL helper exception in ExecuteReader at umbraco.DataLayer.SqlHelper`1.ExecuteReader(String commandText, IParameter[] parameters) at umbraco.cms.businesslogic.web.Domain.<GetDomains>b__0() at umbraco.cms.businesslogic.cache.Cache.GetCacheItem[TT](String cacheKey, Object syncLock, CacheItemPriority priority, CacheItemRemovedCallback refreshAction, CacheDependency cacheDependency, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) at umbraco.cms.businesslogic.web.Domain.GetDomains() at umbraco.cms.businesslogic.web.Domain.GetDomain(String DomainName) at umbraco.requestHandler.CreateXPathQuery(String url, Boolean checkDomain) at umbraco.requestHandler..ctor(XmlDocument umbracoContent, String url) at umbraco.UmbracoDefault.Page_PreInit(Object sender, EventArgs e) at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) at System.EventHandler.Invoke(Object sender, EventArgs e) at System.Web.UI.Page.OnPreInit(EventArgs e) at System.Web.UI.Page.PerformPreInit() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
15.816672
0.006942
Control Tree
Control UniqueID
Type
Render Size Bytes (including children)
ViewState Size Bytes (excluding children)
ControlState Size Bytes (excluding children)
__Page
ASP.default_aspx
Session State
Session Key
Type
Value
Application State
Application Key
Type
Value
vnc38ykjnkjdnk2jt98ygkxjng
System.DateTime
5/9/2014 3:26:51 PM
umbracoUrl
System.String
localhost:80/umbraco
umbracoNeedConfiguration
System.Boolean
False
System.DateTime
5/9/2014 3:26:51 PM
Request Cookies Collection
Name
Value
Size
Response Cookies Collection
Name
Value
Size
Headers Collection
Name
Value
Connection
Keep-Alive
Accept
text/html, application/xhtml+xml, */*
Accept-Encoding
gzip, deflate
Accept-Language
en-US
Host
localhost
User-Agent
Mozilla/5.0 (Windows NT 6.1; WOW64; Trident/7.0; rv:11.0) like Gecko
DNT
Response Headers Collection
Name
Value
X-AspNet-Version
4.0.30319
Cache-Control
private
Content-Type
text/html
Form Collection
Name
Value
Querystring Collection
Name
Value
Server Variables
Name
Value
ALL_HTTP
HTTP_CONNECTION:Keep-Alive HTTP_ACCEPT:text/html, application/xhtml+xml, */* HTTP_ACCEPT_ENCODING:gzip, deflate HTTP_ACCEPT_LANGUAGE:en-US HTTP_HOST:localhost HTTP_USER_AGENT:Mozilla/5.0 (Windows NT 6.1; WOW64; Trident/7.0; rv:11.0) like Gecko HTTP_DNT:1
I would import the application via IIS7 (which is also compatable with IIS6), I change the App pool permissions to Network Services and then I add in the connection strings the credentials for the DB that is combined with the site but it doesnt seem to connect. here is the string "Server=SERVERNAME\SQLEXPRESS;Database=db-001;User ID=db-01". Is ther another want to have the IIS and the DB to connect ? Would I need to install the umbraco 4.0*.
Could you please provide much more detail about your setup? :) As Charlie is pointing out above it seems like your database credentials are wrong. But I'm not sure wether the database has been created on your server or not?
Are you trying to get up and running on a local environment? Or are you trying to deploy to a live environment?
Make sure that you read the documentation on how to install Umbraco - If you dig through it you can find information about system requirements and how to setup permissions as well.
Im not sure on what to do, This is what I have an IIS site from a different server and DB this new server is a win 2k8 R2, IIS 7 capatable with II6 and SQL express 2014
I have only imported the site via IIS import application function. the old server was using umbraco ver 4, do I need to install umbraco ver 4 for the db to work with the IIS site ?
Source Error: Stack Trace:
Source Error:
Stack Trace:
umbraco.DataLayer.SqlHelpers.SqlServer.SqlServerHelper.ExecuteReader(String commandText, SqlParameter[] parameters) +135
umbraco.DataLayer.SqlHelper`1.ExecuteReader(String commandText, IParameter[] parameters) +146
umbraco.DataLayer.SqlHelper`1.ExecuteReader(String commandText, IParameter[] parameters) +228
umbraco.cms.businesslogic.web.Domain.<GetDomains>b__0() +140
umbraco.cms.businesslogic.cache.Cache.GetCacheItem(String cacheKey, Object syncLock, CacheItemPriority priority, CacheItemRemovedCallback refreshAction, CacheDependency cacheDependency, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) +207
umbraco.cms.businesslogic.cache.Cache.GetCacheItem(String cacheKey, Object syncLock, CacheItemPriority priority, CacheItemRemovedCallback refreshAction, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) +120
umbraco.cms.businesslogic.cache.Cache.GetCacheItem(String cacheKey, Object syncLock, CacheItemRemovedCallback refreshAction, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) +117
umbraco.cms.businesslogic.cache.Cache.GetCacheItem(String cacheKey, Object syncLock, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) +114
umbraco.cms.businesslogic.web.Domain.GetDomains() +225
umbraco.cms.businesslogic.web.Domain.GetDomain(String DomainName) +95
umbraco.cms.businesslogic.web.Domain.Exists(String DomainName) +44
umbraco.requestHandler.CreateXPathQuery(String url, Boolean checkDomain) +484
umbraco.requestHandler..ctor(XmlDocument umbracoContent, String url) +777
umbraco.UmbracoDefault.Page_PreInit(Object sender, EventArgs e) +1497
<< An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below >>
Is this becasue I dont have the original pwd and username, I took a db.bak and imported onto the sql express 2008 r2 and then added permission to the .\administrator (dbo).
Network path error
Source Error:
Request Details
Trace Information
Control Tree
Session State
Application State
Headers Collection
Form Collection
Server Variables
Hi Katerina
Could you describe in a bit more details what it is you're trying to do that gives you this error please?
Hello Jan,
Thank you
Katerina
Trace Information
Hi katerina,
Are you able to connect to the database in SQL management studio using those creditials? Does the user have the permissions to access the database?
The problem is the creditials you have are not valid for the SQL instance or the user does not have permissions on the database.
Charlie
Hello Charlie,
Ive added the .\administrator as a owner in the db permissions, do I need to go to into a table and change the the credentials ?
-this IIs site is from a different server and db. do I need to change any settings from the db with a new server name and ip address?
Katerina
Hi Katerina
Hope this helps.
-Katerina
Ok what i would do i go into SQL management studio and try to connect from there first off.
If you have the ip address that will be the serverName. Do you know if you have a user that has SQL Server Authentication on the database?
In SQL Management studio:
Authentication: SQLSERVERAUTHENTICATION
USERNAME:db-01
PASSWORd: Password for the database
Once you can log into the database doing that try those settings in the web config.
If that does still does not work it will be because the user does not have sufficent permissions for the database which you will need to apply :)
Charlie :)
Im still getting the error
Source Error:
Stack Trace:
Hi katerina
Have you got sql management studio? Have you tried logging in with those credenitials?
Could you try the crentials in management studio like this and let me know if you can login?
Charlie
I can log in
<add name=umbracoDbDSN" connectionString="server=.\SQLEXPRESS;database=db-SOW12; UserID=administrator;password=********"providerName="System.Data.SqlClient" />
Ok so can you try this connection string and see if you get any further :).
Charlie
Hi for some reason i cannot see your comments but i made a typo sorry should be
<add name="umbracoDbDSN" connectionString="server=.\SQLEXPRESS;database=db-SOW12; UserID=administrator;password=********"providerName="System.Data.SqlClient" />
Source Error:
Trace Information
at umbraco.cms.businesslogic.cache.Cache.GetCacheItem[TT](String cacheKey, Object syncLock, CacheItemPriority priority, CacheItemRemovedCallback refreshAction, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem)
at umbraco.cms.businesslogic.cache.Cache.GetCacheItem[TT](String cacheKey, Object syncLock, CacheItemRemovedCallback refreshAction, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem)
at umbraco.cms.businesslogic.cache.Cache.GetCacheItem[TT](String cacheKey, Object syncLock, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem)
at umbraco.cms.businesslogic.web.Domain.Exists(String DomainName)
Ok, where is your website and where is your database?
Are they on the same machine?
Yes they are on the same server.
