Hey, Y'all
I have several webpages on one installation. One of the url´s goes to the first node and not the other as it should.
Domains on IIS is up and running.And the Umbraco domains in Culture and Hostnames is up and running.
What can I do?
Regards, Johan
Hi Johan
Does the domain contain any weird characters like æøå?
And has the
What is set to true?
I have 2 domains that works, and no one is with æøå.
My structure
UnderOpbygning #1 - domain#1 - ok
UnderOpbygning #2 - domain#2 - lands on domain#1
Hestewrap - domain#3 - ok
Argh that damn markdown editor - strips out code snippets or what looks like code snippets if it's not marked as code.
<useDomainPrefixes> should be set to true. It is set so already?
<useDomainPrefixes>
it works now, I do not know what has gotten it to work.
Jan thanks for the help.
That sounds odd - but glad it's working now.
But please for your own sake make sure that the setting I mentioned above is set to true since it can lead to duplicate content issues if you don't do it. You don't want to deal with that SEO wise if you can avoid it up front.
done :)
thank you jan!
umbraco 6 multiple sites do not go to the right url
Hey, Y'all
What can I do?
Regards, Johan
Hi Johan
And has the
My structure
<useDomainPrefixes>should be set to true. It is set so already?/Jan
Hi Johan
done :)
thank you jan!
