I'm looking for a way to prevent TinyMCE from insterting style tags. I followed the instructions from an article called Responsive Images in Umbraco, but it seems like no matter what I do to the files, it has ZERO effect on my test site.
After making the changes, I tried saving the web.config file and republishing the site. Still nothing...
Have you set "debug" to true in the web.config? Also try browsing the backoffice having the console log open i Chrome since this sould clear the cache. In v7 the cache is a bit extreme currently...that may be the reason why your changes don't take effect.
A note on the stuff from the article...
I prefer having these settings in regards to image dimensions
img{
max-width:100%;
height: auto;
This should keep the aspect ratio of the image intact.
TinyMCE - How do I prevent TinyMCE from instering style tags?
Try changing the version in the ClientDependency.config and recycle the application pool.
Moshe
Hi Alex
