Also try and see if some more information about the issue is revaled in the trace log in /app_data/logs - Does it contain any entries marked with "ERROR" ?
System.Configuration.ConfigurationErrorsException: The configuration file has been changed by another program. (C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Config\machine.config)
at System.Configuration.BaseConfigurationRecord.GetSection(String configKey)
at System.Configuration.ConfigurationManager.GetSection(String sectionName)
at System.Configuration.PrivilegedConfigurationManager.GetSection(String sectionName)
at System.Data.Common.DbProviderFactories.Initialize()
at System.Data.Common.DbProviderFactories.GetProviderTable()
at Umbraco.Core.Persistence.Database.CommonConstruct() in d:\temp\UmbracoV7Branch\src\Umbraco.Core\Persistence\PetaPoco.cs:line 202
at Umbraco.Core.Persistence.UmbracoDatabase..ctor(String connectionStringName) in d:\temp\UmbracoV7Branch\src\Umbraco.Core\Persistence\UmbracoDatabase.cs:line 42
at Umbraco.Core.Persistence.DefaultDatabaseFactory.CreateDatabase() in d:\temp\UmbracoV7Branch\src\Umbraco.Core\Persistence\DefaultDatabaseFactory.cs:line 83
at UmbracoExamine.DataServices.UmbracoContentService.GetAllUserPropertyNames() in d:\temp\UmbracoV7Branch\src\UmbracoExamine\DataServices\UmbracoContentService.cs:line 125
System.ArgumentException: Unable to find the requested .Net Framework Data Provider. It may not be installed.
at Umbraco.Core.Persistence.Database.CommonConstruct() in d:\temp\UmbracoV7Branch\src\Umbraco.Core\Persistence\PetaPoco.cs:line 216
Could you be missing a framework or an framework update perhaps? From one of the error entries above it says "System.ArgumentException: Unable to find the requested .Net Framework Data Provider. It may not be installed."
I find that the easiest way of making sure the all the required dependencies for ensuring Umbraco runs smoothly is by making an installation of Umbraco using Webmatrix, since it makes sure all dependencies are installed before it tries to install Umbraco. I don't use the installed Umbraco version for anything and just remove it afterwards.
I understand that - just trying to provide some pointers and ruling out some of the usual suspects.
But could you tell a bit more about the project? Do you have access for it locally? Or does it live on a server you need to log onto? What is the setup in other words?
Just a thought...is there any chance that you could try installing a clean Umbraco 6.1.6 version on the server as well to see if the problem also occurs on that installation?
Just to figure out wether or not it's a general problem with Umbraco on that server or if it's specifically with the current site running.
In the members section the aspx pages have css and javascript references using the "DependencyHandler.axd".
But the webserver seems to be looking for the DependencyHander in foder /umbraco/members/
If I add <base href="https://www.thedomainname.com/umbraco/" /> to the master page then the pages are rendered almost correctly (the save buttons images are not showing, but at least saving is now working).
Anyone who knows how so configure my project so that it finds the DependencyHandler correctly?
Member section interface is broken
Hey.
In a project I inherited the member section is broken "jquery not found":
What's strange is that the problem is only in the members section.
Anybody know a fix for this?
http://www.fbd.be/umb-members.jpg
Hi There
Make sure that your permissions have been setup correctly according to this piece of documentation http://our.umbraco.org/documentation/Installation/permissions
...What Umbraco version is it btw?
The permissions are not the problem.
The version is 6.1.6
I do see errors in that log that are probably the cause. Don't really know what to do about them thou :-D
2014-05-16 11:48:40,572 [13] ERROR UmbracoExamine.DataServices.UmbracoContentService - [Thread 25] EXCEPTION OCCURRED reading GetAllUserPropertyNames
at System.Configuration.BaseConfigurationRecord.EvaluateOne(String[] keys, SectionInput input, Boolean isTrusted, FactoryRecord factoryRecord, SectionRecord sectionRecord, Object parentResult)
at System.Configuration.BaseConfigurationRecord.Evaluate(FactoryRecord factoryRecord, SectionRecord sectionRecord, Object parentResult, Boolean getLkg, Boolean getRuntimeObject, Object& result, Object& resultRuntimeObject)
at System.Configuration.BaseConfigurationRecord.GetSectionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object& result, Object& resultRuntimeObject)
2014-05-16 11:48:40,587 [13] ERROR UmbracoExamine.DataServices.UmbracoContentService - [Thread 25] EXCEPTION OCCURRED reading GetAllUserPropertyNames
2014-05-16 11:48:40,603 [13] ERROR UmbracoExamine.DataServices.UmbracoContentService - [Thread 25] EXCEPTION OCCURRED reading GetAllUserPropertyNames
Ok, then try doing the following
1: Go to /app_data/TEMP/ and delete all folders from there 2: Recycle the app pool
Do you still have the weird issue in the member section? And do you still see the above errors?
Sadly, it didn't fix the problem.
Hope this helps.
The thing is, it is an inherited project (from another company), we have no idea what was done to it before :-)
I will try your suggestion.
K
Yes, I have a dev version a staging version and a live version.
Only the live version (with SSL - https) has the problem.
Regards?.
K.
Hi K
Hey.
I found the culprit.
Thank you.
K.
