I'm pretty new to the umbraco experience so please forgive me if this is a newbie question. I'm using the latest version of umbraco (version 7) and have implemented a new document type that makes use of the property type tags. However, when I try to content manage the tags for example add one tag to my page it doesn't save it to the database? It just says saves successfully, but then when I click off the page and go back the tag is gone? When checking the database there are no tags within the cmsTags db?
Is there something I need to do to get this working?
What exact version of Umbraco are you using? Does it say 7.1.3 when you click the help section? If not you need to upgrade to this version since there unfortunately is a bug with the tags property editor in earlier versions of Umbraco. You can read about the issue here http://issues.umbraco.org/issue/U4-4869 - And from that page it seem to have been fixed.
If you're using 7.1.3 then please do add a new comment that you're still seeing the issue and provide as much information as possible (Database, operating system, browser etc. - Stuff like that).
I have found that if you press enter once you have typed a tag then the tag is populated into the tag box. I wasn't aware of this but after playing around a bit more with umbraco ui this become apparent.
Tags not saving in umbraco backend?
Hello All,
Hi Mark and welcome to our :)
If you need to upgrade then you can download the latest version here http://our.umbraco.org/contribute/releases/713 and then follow the upgrading instructions mentioned.
Hope this helps.
Hey Jan,
Many thanks for your reply! :)
To be clear, this is not an issue anymore.
Hi Mark
Aaah, ok - Yes it's actually the third time this week I see people having issues figuring out how it actually works.
But at the same time there has been the issues I mentioned above as well so thought that it was that you we're struggling with.
But happy to hear you got it figured out - Remember to mark the post as solved so others can see the solution as well.
Cheers, Jan
