  • Mark 7 posts 28 karma points
    May 24, 2014 @ 22:22
    Mark
    Using a class from the app_code folder not working.
    I've created a class in the app_code section of my website and instantiated this class into my macro, however it doesn't seem to work. I tested the linq and functionality in a winform application and seems to work in the way i want to... just doesn't seem to render using the macro, here is what i have:
    Macro:
    @using umbraco.MacroEngines
    @using umbraco.MacroEngines.Library;
    @inherits umbraco.MacroEngines.DynamicNodeContext
        DynamicNodeList pages = @Model.Children.Where("Visible").OrderBy("CreateDate desc");
        Common com = new Common();
        List<string> tags = new List<string>();
        string[] top10 = @com.GetTop10Tags(@pages);
        foreach(string tag in @top10)
            <ul>@tag</ul>
    App_Code - Common Class:
    using System;
    using System.Linq;
    using System.Web;
    using umbraco.MacroEngines;
    public class Common
        public string[] GetTop10Tags(DynamicNodeList pages)
            foreach (var node in pages)
                string[] aTags = node.GetPropertyValue("postTags").Split(',');
                foreach (string tag in aTags)
                    tags.Add(tag);
            string[] orderedList = tags
                .GroupBy(i => i)
                .OrderByDescending(g => g.Count())
                .Select(g => g.Key).ToArray();
            return orderedList;
    Does anyone see what the problem here is?
    Error: Error loading MacroEngine script (file: TagCloud.cshtml)
    May 25, 2014 @ 00:17
    Mark
            foreach (DynamicNode node in pages)
                if (node.GetPropertyValue("postTags") != null)
                        tags.Add(tag);
                .GroupBy(i => i)
                .Select(g => g.Key).Take(10).ToArray();
            return orderedList;
    I got this working by using the above code, not sure why this is the case but by switching the var to DynamicNode helped, as well as adding validation after the foreach to check if the node contains any tags within the tag property... :)
