    Nov 13, 2009 @ 09:40
    Kim Andersen
    Problem with macros in RTE in IE7
    One of my clients have some issues with macroes in the richtext editor when I run IE7.
    This is my first problem:
    When I insert a macro in the richtext it works just fine. But if I try to insert another macro in the same richtext editor, the first inserted macro dissapears when i save and publish the page. This only happens in IE. In Firefox it works just as it was supposed to, where both of the macros stays on the page.
    The second one:
    If I have created a page with two macros (made in Firefox off course), and wan't to edit the page in IE, something is going wrong. If I wan't to edit one of the inserted macros, I mark it in the editor with a click, and choose the "Insert macro"-button. Here I can either delete the choosen macro, choose a new one or just click the OK-button without any changes. Nomatter how I do it, I can't get this to work in IE. Because when I click the OK-button in the bottom left corner, the dialog-box doesn't go away. Actually I also get's an error in the browser saying this:
    Error
    IE macro error
    I can't figure out what's going wrong, but it's a big problem because almost all of the users in my clients company uses Internet Explorer.
    Anyone have some inputs?
    Thanks.
    /Kim
  • Chris Houston 535 posts 980 karma points MVP admin c-trib
    Nov 13, 2009 @ 10:09
    Chris Houston
    Hi Kim,
    Which version of Umbraco are you using?
    Chris
    Nov 13, 2009 @ 10:26
    Kim Andersen
    Feb 11, 2010 @ 20:08
    Kim Andersen
    Bump. I'll give this one another try. Maybe some of you guys have seen something like this before, or tried something similar?
    /Kim A
