Ok, what's the trick to allowing javascript code inside the TinyMCE editor in Umbraco?
I've added the script tag as a valid element inside my tinymce config file, which initially appeared to work. However, tinymce wraps your javascript code in a CDATA block and I get the following error when I try to publish:
Cannot have ']]>' inside an XML CDATA block.
Exception Details: System.ArgumentException: Cannot have ']]>' inside an XML CDATA block.
Is anyone using javscript with TinyMCE? How are you doing it?
If the 'render in editor' box in unchecked, then I get a message saying "This macro does not provides rendering in WYSIWYG editor<\/span>"
If the box is checked, then I get an error saying "Macro rendering contains script code This macro won\'t be rendered in the editor because it contains script code. It will render correct during runtime."
In both cases nothing is inserted into the text editor and the dialog where I input the script stays on screen.
I don't think it's possible to render javascript in tinyMCE, but the macro should act as a placeholder to get your javascript into the web page upon publishing.
yes I get that message, but the popup box where i'm pasting the code remains on screen so i'm unable to publish. I have to cancel the popup which means the macro isn't inserted.
These two steps worked for me. Step one is a config step, step two is a little hack in the TinyMCE javascript.
1..\Website\config\tinyMceConfig.config
a.Add “,script[type|src|language]” (without the quotes, but with the starting comma) to the list of allowed tags. This should be on line 231, before the final ‘]]>’
I have similar problem in Umbraco 6.1.3 MVC mode but Andrew's solution doesn't work unfortunately.
I've created razor macro for inserting HTML/CSS/js code snippets to page in RTE. Macro has one text field where user should paste source code. If pasted code contains <script> tag, insertion fails and following error is shown in dialog bottom:
"', 'Editor - Code Snippet', '
Editor - Code Snippet<\/strong> No macro content available for WYSIWYG editing<\/span>
Before inserting source code with script tag to macro field, html encode it (with this for example). Then it works as intended because source code highlighter (js lib I use to style code) expects html encoded content.
But this is only workaround, it would be good to have better solution.
Thanks, but it didn't work for me!
I'm trying to insert a hubspot form script, but it gets removed by tinyMCE, as I save. Here is the code that I insert:
Javascript In TinyMCE Editor
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.Exception Details: System.ArgumentException: Cannot have ']]>' inside an XML CDATA block.
-Todd
I created a macro with one parameter (textmultiline), then just display that with disable-output-escaping="yes"
Then it's a case of pressing insert macro, pasting in the script include and publishing. (after turning off "render in editor")
Dan
I can't get this to work.
That's what I've tried, but the macro won't allow me to paste the Javascript in.
Make sure "render in editor" is disabled, then you should just see
But when publishing you'll see the code output. The macro will just be a textarea that you will be able to paste into.
Dan
Poop, I just tried it and if there are script tags it won't insert. Either this behaviour changed since Nov or I'm losing it.
Simple fix is to wrap the script tags around your output within your xslt and not within the macro, so your macro would be something like
And in the macro box you'd just paste e.g.
alert("hiya");
Dan
That works better, but it won't work if the code contains quotes. It seems they interfere with the other quotes in the macro.
I've tried escaping them and encoding them (") but neither works.
Single quotes work ok though.
umbraco.library:Replace() might help to overcome that, but g;ad you got it working somewhat.
a. Add “,script[type|src|language]” (without the quotes, but with the starting comma) to the list of allowed tags. This should be on line 231, before the final ‘]]>’
2. ..\Website\umbraco_client\tinymce3\tiny_mce_src.js
a. Comment out “'script' : /]*>/gi,”, which should be on line 1983
b. This is part of the following block of code:
attrRegExp = /([\w:\-]+)(?:\s*=\s*(?:(?:\"((?:\\.|[^\"])*)\")|(?:\'((?:\\.|[^\'])*)\')|([^>\s]+)))?/g;
specialElements = {
'script' : /]*>/gi,
'style' : /]*>/gi,
'noscript' : /]*>/gi
In the function “processEndTag(name)”
Step 1 tells TinyMCE that the script tag is to be considered valid and should not be removed.
Step 2 prevents TinyMCE from trying to wrap javascript in CDATA tags, which cause nested CDATA errors.
I am having the same issue, I do not see 'script' : /]*>/gi, in the line 1983. I am trying to test your solutions Adrew I would appreciate your help.
Are you able to find the block or the functionI mentioned, Jose?
Line numbers might differ, but if that block is there, in the “processEndTag(name)” function, you should be in the right place.
yes, thanks a lot, now I am having troubles to reaload the changes in my site. I think that is something about client dependecy.
I clear the browser cache. and now it is working, thanks a lot.
Any ideas how to make this work in MVC?
Found partial workaround for my issue:
Just add this to config/tinyMceConfig.config -> validelements:
just before: ]]>
Hi Amigo,
Thanks, but it didn't work for me! I'm trying to insert a hubspot form script, but it gets removed by tinyMCE, as I save. Here is the code that I insert:
<!--[if lte IE 8]> <script charset="utf-8" type="text/javascript" src="//js.hsforms.net/forms/v2-legacy.js"></script> <![endif]--> <script charset="utf-8" type="text/javascript" src="//js.hsforms.net/forms/v2.js"></script> <script> hbspt.forms.create({ sfdcCampaignId: '*', portalId: '*', formId: '*' }); </script>
Oh, I had to add '|charset' to it.
Hi Siavash,
So did you get it working? what version are you using?
