Maybe it is a bit rude to ask for fast answer but i need it to be solved this evening tho. I would appreciate if you answer the questions also if it is only 1 question of the thing i listed below. All help is welcome :)
How can i change the Mailfrom: in the cultirazor contact from? I implemented it like: @Umbraco.RenderMacro("Contactform") in my template. Because if i do it on another way i can't see my layout.
Installing ucommerce but i don't get it in the left toolbar yet it says that ucommerce is installed. I heard something about SQL CE that it doesn't work with that. Well i tried to change to SQL server but i didn't go as i want. I had to begin over because i couldn't log in on umbraco anymore :/
When a user logs in he can use the page webshop (wanna make that with ucommerce, some explanation about howto is allways welcome). If a user is not logged on, he can't use the page.
Need some fast answers on these questions.
Hi, Maybe it is a bit rude to ask for fast answer but i need it to be solved this evening tho. I would appreciate if you answer the questions also if it is only 1 question of the thing i listed below. All help is welcome :)
Maxim
