  • alexei 21 posts 40 karma points
    Nov 16, 2009 @ 10:09
    alexei
    inserting macro
    I have a macro which I need insert into my article. I have two fields. The first is included directly to template and it is working fine. The second field included in template with another macro, and when I try to use inline macro (<umbraco:Macro Alias="MyMacro" runat="server"></umbraco:Macro>) inside html nothing happens.
    I appreciate any help you can offer.
    Alexei
  • Chris Houston 535 posts 980 karma points MVP admin c-trib
    Nov 16, 2009 @ 10:18
    Chris Houston
    Hi Alexei,
    The mark up used when you insert Macros inline is different. Try clicking on the Macro button above your Richtext editor and insert the macro that way.
    As an example here is a simple macro ( with dummy data ) inserted inline:
    <p>
    <div umb_macroalias="Footer" ismacro="true" onresizestart="return false;" umbversionid="427b6dcd-38b0-4576-b12e-da7236f2706e" umbpageid="1068" title="This is rendered content from macro" class="umbMacroHolder"><!-- startUmbMacro -->
    <div class="Footer">
    <div id="FooterMenuSection">
    <ul>
    <li><a href="/">Services</a>
    <ul>
    <li><a href="/">Example service</a></li>
    <li><a href="/">Example service 2</a></li>
    </ul>
    </li>
    </ul>
    <!-- endUmbMacro --></div>
    </p>
    Chris
    Nov 16, 2009 @ 11:38
    alexei
    Chris, thanks but it doesn't work
    Firstly I use simple editor in this field. Secondly I'd tryed to insert code from RTE which is similar to your suggestion. But it did't help.
