How to remove "About US" from top navigation but still display "Contact" macro on homepage
I have a need to "not show" the "About Us" in top navigation. But I still need to be able to see the Contact details ( which are set using the contact macro") on the homepage. If I unpublish the "About Us", the child node "contact US" also disappears from the bottom of homepage. How can i still show the contact deatils?
You can hide the about us item from the top navigation by added a propperty on your document type, the type should be an true/false type, and should have an alias of umbracoNaviHide. And if you are using razor, you should add .where("visible"), an example could be:
@{ <ul> @* For each child page under the root node, where the property umbracoNaviHide is not True *@ @foreach (var childPage in CurrentPage.Children.Where("Visible")) { <li> <a href="@childPage.Url">@childPage.Name</a> </li> } </ul> }
It will only appear if it not has the umbracoNaviHide set to true.
Please help.
Thanks Shilpi
Hi sg,
@{<ul>
<li>
</li>
</ul>
Here is some more info about it: http://our.umbraco.org/wiki/reference/umbraco-best-practices/umbraconavihide
Hope this helps, if you want more detailed information about it, just say, and I will try to help you further.
/Dennis
Hello! I'm create Contact. when customer input field in form and submit. I'm view in Umbraco Admin. I don't want contact show in menu. Please help me
Hi user111
When you say you don“t want to show contact in menu do you mean on the front-end of your site. If so try to see.
https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/73459-hide-from-navigation#comment-235423
Hope this helps,
/Dennis
Thank you Dennis!
