  • Björn 10 posts 90 karma points
    Jun 09, 2014 @ 14:11
    Björn
    Startpage redirection without changing url
    Hey guys! I have a page with the following structure:
    -mysite.com
    ---/people.aspx
    ---/companies.aspx
    ---/aboutUs.aspx
    When you access
    mysite.aspx
    you get redirected to
    mysite.com/people.aspx
    which is the start page.
    What I would like to do is to keep this redirect but I want the url to be just
    mysite.aspx
    (even though it's pointing towards mysite.com/people.aspx). I've been told that this is beneficial for SEO purposes.
    However, if you go directly to mysite.com/people.aspx (e.g from /companies.aspx) you should see the full path.
    Any ideas of how this could be done?
    Using Umbraco 6.1.5 with asp.net 4.0 classic.
    Thanks!
    Jun 10, 2014 @ 14:58
    Björn
    Solved it myself:
    Found this page http://our.umbraco.org/wiki/reference/umbraco-best-practices/umbracoredirect and did something similar!
    I changed "umbracoRedirect" to "umbracoInternalRedirectId" (just like it said you should when working with the top-most node.)
