  • David Monaghan 2 posts 22 karma points
    Nov 16, 2009 @ 16:53
    David Monaghan
    background image issue with Internet Explorer 8
    Hi there, I am a newbie to Umbraco. My site was working fine up until recently when a background image started to tile in front of the content ONLY in Internet Explorer 8. It works OK in Firefox, Chrome, Safari. I checked the validation of the CSS and all seems OK. website: http://www.payrollday.ie/
    ANY ideas on how to fix this?
    Nov 16, 2009 @ 17:07
    dandrayne
    I'd start by validating the html > http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.payrollday.ie%2F , looking especially at the unclosed divs.
    Then, most IE CSS problems can be solved by generous sprinklings of clearing floats and position:relative;
  • Amir Khan 1289 posts 2746 karma points
    Nov 16, 2009 @ 18:26
    Amir Khan
    Looks like you have some issues with your templates also, you have DOCTYPE declared twice...
    Nov 16, 2009 @ 18:27
    Amir Khan
    Also, some duplicate id's
  • Chris Houston 535 posts 980 karma points MVP admin c-trib
    Nov 16, 2009 @ 18:41
    Chris Houston
    Hi David,
    If you don't already use it, I would highly recommend using the following when developing:
    1) Firefox
    2) Firefox Addin - Firebug ( Are there any web developers who don't use this every day!? )
    3) Firefox Addin - HTML Validator ( This is based on HTML tidy and validates every page as you view it so you can instantly see any HTML / XHTML errors. )
    When you have fixed the basic HTML issues it should be easier to figure out why your image is showing up at the wrong z-index.
    Chris
    Nov 17, 2009 @ 22:26
    David Monaghan
    Hi guys, yeikes! 25 errors with validating the HTML! Many thanks for your tips and suggestions - much appreciated. I'll start with correcting the errors I find.
    thanks again!
    David
