Backend Error: The incoming request has too many parameters.
I have a list of Hotels under an umbraco folder container and when i press the arrow to open the folder and enumerate the documents within the folder in the backend treeview i am getting the following error.
The incoming request has too many parameters. The server supports a maximum of 2100 parameters. Reduce the number of parameters and resend the request.
Ok, this might be a long shot but could you try doing the first 3 tweaks mentioned in this article http://24days.in/umbraco/2013/6-easy-configuration-tweaks/ by Jeavon Leopold and see if that changes anything? In particular I think the JSON stuff could perhaps fix the issue.
Unfortunately following the first three steps does not resolve the issue.
Thank you for the help but probably something else must be done.
For the records following is the error i am getting:
Exception Details: System.Data.SqlClient.SqlException: The incoming request has too many parameters. The server supports a maximum of 2100 parameters. Reduce the number of parameters and resend the request.
Source Error:
We started getting this error following an upgrade from 4.11.5 to 6.2.4. but I tracked the issue down to SQL Server as our development server was running a newer service pack than our client's production server - SQL Server 2008 R2 SP3 and SQL Server 2008 R2 SP2 respectively.
Microsoft did release a CU that addressed the issue - see here but I'd apply the latest SP if you're not already running it as they include fixes and performance improvements.
Any Help how to resolve the issue?
Hi Thomas
What version of Umbraco are you using?
I am using 1.6.2.1
Hi Thomas
Hi, thank you for the reply. I will tey that on sunday because I am away now, and I will reply the results.
Unfortunately following the first three steps does not resolve the issue. Thank you for the help but probably something else must be done.
Server Error in '/' Application. The incoming request has too many parameters. The server supports a maximum of 2100 parameters. Reduce the number of parameters and resend the request. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Source Error:
Stack Trace:
[SqlException (0x80131904): The incoming request has too many parameters. The server supports a maximum of 2100 parameters. Reduce the number of parameters and resend the request.] System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action
1 wrapCloseInAction) +1789294 System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) +5340642 System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) +244 System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) +1691 System.Data.SqlClient.SqlDataReader.TryConsumeMetaData() +61 System.Data.SqlClient.SqlDataReader.get_MetaData() +90 System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +377 System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds) +1421 System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource1 completion, Int32 timeout, Task& task, Boolean asyncWrite) +177 System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) +53 System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method) +137 System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior) +81 Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteReader(String connectionString, CommandType commandType, String commandText, SqlParameter[] commandParameters) +146 umbraco.DataLayer.SqlHelpers.SqlServer.SqlServerHelper.ExecuteReader(String commandText, SqlParameter[] parameters) +37 umbraco.DataLayer.SqlHelper1.ExecuteReader(String commandText, IParameter[] parameters) +81[SqlHelperException: Umbraco Exception (DataLayer): SQL helper exception in ExecuteReader] umbraco.DataLayer.SqlHelper`1.ExecuteReader(String commandText, IParameter[] parameters) +201 uComponents.UI.ItemInfoService.ProcessRequest(HttpApplication app) +1109 uComponents.UI.uComponentsModule.
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.34212
Hope this helps,
James.
