  • Bent Holz 100 posts 273 karma points
    Jun 17, 2014 @ 21:50
    Bent Holz
    Umbraco 6.2.1 won't always save changes...
    I just created a fresh install of Umbraco 6.2.1 and I'm having problems with Umbraco not saving things like style or template changes... I'v been trying to recreate the error but cnaøt figure out what the problems is.
    Some times it saves and sometimes it doesn't - even though the "pop-up" clearly states "Stylesheet saved without any errors"...
    Anyone else having these problems?
    Jun 20, 2014 @ 17:56
    Hi Crawn
    Not sure what the issue could be but perhaps looking at the /app_data/logs file could reveal some useful information?
    What browser are you using?
    And is there a specific reason why you're editing the code within Umbraco rather than using an external editor?
    Jun 23, 2014 @ 15:04
    Bent Holz
    Hi Jan...
    Don't know why this is happening. It happens on different browsers and on both Mac and PC... Think i'll do a re-install and see if that solves anything.
    I'm also having problems with not being able to edit the code, if I just saved it. Then I need to click some where else like in the setting tree...
    Why not edit CSS or templates directly in Umbraco?!?
    /Crawn
    Jun 23, 2014 @ 21:51
    Hi Crawn
    Ok, please let us know how the re-installation goes.
    Well Umbraco is a CMS not a code editor and the IDE is not really that great. But it's good enough for when you need to do those minor quick fixes. But usually you're way better of using proper editors like visual studio, sublime text, textmate or whatever editor you prefer to edit your .css, .js, .xslt and .cshtml files since they have support for code completion, themes, font size and some of them feature intellisense etc.
    And then you don't have to struggle with weird save issues like the one you're experiencing above ;-) - I'm not saying the issue should not be fixed but editing code in Umbraco should not be the preferred way of doing it in my humble opinion - To me it's like doing a steak using a toaster :)
    Hope this helps.
