  • Daniel Nøhr 14 posts 35 karma points
    Nov 19, 2009 @ 10:20
    Daniel Nøhr
    How to use Media library for user upload
    Hello..
    I was wondering how to use the Umbraco media library for a user upload function. I've got a user page where the user can create a page node.. This page node, needs to be extended with some user uploads, like pictures..
    Would you recommend this setup for getting user submitted content or should I use another folder and my custom library instead? This is NOT from the umbraco administration, but the client page, at frontend.
    Hopefully some of you, have been working for such a solution :-)
    Nov 20, 2009 @ 07:50
    Daniel Nøhr
    bump :)
  • Shaun 248 posts 475 karma points
    Nov 20, 2009 @ 11:40
    Shaun
    I would be tempted to create a new user that only has access to that particular page, then allow them to create subnodes from that page, each containing a media item, using the standard umbraco admin.
    However that may not suit your site as you may have a huge number of potential uploaders, so the alternative I'd look into would be building a new .Net control that you can slap onto the relevant template as a macro.
    The control could then contain a file upload field and would ftp the files into the media library using the umbraco api. You could create a new folder for generic uploads in the media library and point it to that.
    I've not done this myself, but a starting point might be here - http://forum.umbraco.org/yaf_postst2317_File-repository.aspx
    Nov 24, 2009 @ 14:32
    Daniel Nøhr
    Thanks for the link Shaun.
    I think I just create my own file depot for my node images, because i won't let my users into my umbraco administration for a simple upload.
    Anyway, your answer will get the proved status :-)
    Nov 24, 2009 @ 14:39
    dandrayne
    You could also use Doc2Form for both creating the node and uploading images (via an image upload data type on the document used to create a Doc2Form form)
    Dan
