In my project i have two modes called zakeljik & consument. For each mode there are different UI. I have set one session variable for this mode programmatically. I have two template for each mode. Now for one node i want to apply alternate template depending on mode. Can anyone tell me any solution for this?
I'm not sure if I completely understand the motive, but you can set templates as follows: If you have a page at page.aspx and a template called "template", you can apply the template via the url
You can achieve what you want with alternative templates, but I think it'd be worthwhile investigating an alternative master page approach. You would programatically change the master page (overall look and feel) without changing the actual template.
Hi , thanks for the reply. in my queries for the mode i have one link. for first click i want to apply one template and for another click i want to apply different template for the sam enode. where exactly i will use this "page.aspx?altTemplate=template-newtemplate"
How to set alternate template for the node
Thanks in advance
Suvarna
e.g.
and
Hope this starts you in the right direction
http://our.umbraco.org/forum/developers/api-questions/3687-dynamic-master-page
Hi , thanks for the reply. in my queries for the mode i have one link. for first click i want to apply one template and for another click i want to apply different template for the sam enode. where exactly i will use this "page.aspx?altTemplate=template - new template"
or how can i do this programmatically?
Suvarna
