Where did advanced options for images and links in TinyMCE go?
Hey hey!
This has been puzzling me for a while... In v3, the rich text editor had an "advanced options" item in the context menu for images and links, allowing you to assign classes, borders, margins, alignment etc. to the element.
However, this option seems to have disappeared in v4 (in earlier versions I've seen a menu item called image.adv_desc, but it didn't bring up a dialog).
The settings page / pre-value editor for TinyMCE still has the "Enable advanced settings for" section, but it doesn't seem to do anything.
This seems to be the case for every v4.0.1+ installation I've checked, so it's clearly not just one flunky installation messing up.
Can anyone tell me if this behavior is by design, or if I'm missing something obvious?
Hey hey!
Thanks in advance!
I'm afraid it's by design. This thread should help you
http://forum.umbraco.org/yaf_postst8163_TinyMCE--insert-image-dialog.aspx
Hey Petr, thanks for your reply and the link, I'll give it a go!
