  • Daniel Horn 319 posts 344 karma points
    Nov 23, 2009 @ 15:28
    Daniel Horn
    Nodes don't autoreload
    I'm running Umbraco 4.0.1 on win2008 server.
    Everything is working perfectly except for the tree list - which doesnt autoreload the nodes when you for example create a new node.
    Does anyone have some ideas on how to fix this?
  • Nico Lubbers 151 posts 175 karma points
    Nov 23, 2009 @ 15:31
    Nico Lubbers
    This is a pain indeed, the good news is that you only heve to wait until 4.1 is final. There it is solved.
    Nico
    Nico Lubbers
    For now... you just need to reload the parent node to see the newly created nodes too.
    Nov 23, 2009 @ 16:05
    Daniel Horn
    Damn :( - that is kinda sucky.
    Well - as long as there is a light in the end of the tunnel :)
