Links to articles under the 3d level works only for current domain others are't reachible
(umbraco tried this to match it using this xpath query'/domainprefixes-are-used-so-i-do-not-work')
I tried use NiceUrlFullPath: the situation changed vice versa all domains exept current begin working. On curent domain I get top level folder inside url ( <add key="umbracoHideTopLevelNodeFromPath" value="true" />)
Help me please to solve one of this problems or better both
to minimize coding and errors we build modified NiceUrl which works exactly like NiceUrlFullPath but without a bug with toplevel folder. You may test following code if you have same problem
Any comments from umbraco gurus will be appriciated
using
System;
using
System.Data;
using
System.Globalization;
using
System.Configuration;
using
System.IO;
using
System.Net;
using
System.Net.Mail;
using
System.Text;
using
System.Text.RegularExpressions;
using
System.Web;
using
System.Web.UI;
using
System.Xml;
using
System.Xml.XPath;
using
umbraco.BusinessLogic;
using
umbraco.cms.businesslogic;
using
umbraco.cms.businesslogic.media;
using
umbraco.cms.businesslogic.member;
using
umbraco.cms.businesslogic.propertytype;
using
umbraco.cms.businesslogic.relation;
using
umbraco.cms.businesslogic.web;
using
umbraco.cms.helpers;
using
umbraco.presentation.cache;
using
umbraco.scripting;
using
umbraco.DataLayer;
using
umbraco.presentation.templateControls;
using
System.Web.Security;
using
umbraco.cms.businesslogic.language;
using
umbraco.presentation.nodeFactory;
using
umbraco.interfaces;
using
umbraco;
namespace
myUrl
///<summary>
/// Function library for umbraco. Includes various helper-methods and methods to
/// save and load data from umbraco.
/// Especially usefull in XSLT where any of these methods can be accesed using the umbraco.library name-space. Example:
niceurl > 3rd level
I have a list of articles which includes items from several sub-domain sites. I used niceUrl and get the same problem as here http://our.umbraco.org/forum/using/ui-questions/3502-Problem-with-useDomainPrefixes---no-unique-URL-starting-with-3rd-level?p=0 ;
May be I can use Alternative Links? How?
it is very important for my site, SOS!
upd
I forget to say that I implemented the solution form this discussion our.umbraco.org/.../3502-Problem-with-useDomainPrefixes---no-unique-URL-starting-with-3rd-level but it's to much additional coding.
ok, no choice :(
O! sorry for formating
Which file is this supposed to replace? (if any :))
If I knew that I may be able to reformat it, but at the moment I am clueless
