  • Tom 50 posts 100 karma points
    Nov 24, 2009 @ 12:59
    Tom
    Remove node gives System.OutOfMemoryException
    When we try to remove a article (node) we are facing the errormessage below.
    We are using Umbraco 4.0.2.1 and the Blogpackage.
    12.000 nodes.
    Windows 2003, IIS, SQL 2005, dual xeon, 8gb memory
    The application is running on a seperate application pool.
    Errormessage:
    Exception Details: System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
    [OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.]
       System.String.GetStringForStringBuilder(String value, Int32 startIndex, Int32 length, Int32 capacity) +29
       System.Text.StringBuilder.GetNewString(String currentString, Int32 requiredLength) +69
       System.Text.StringBuilder.Append(String value) +97
       System.IO.StringWriter.Write(String value) +34
       System.Xml.XmlTextEncoder.WriteRawWithSurrogateChecking(String text) +104
       System.Xml.XmlTextWriter.WriteCData(String text) +185
       System.Xml.XmlCDataSection.WriteTo(XmlWriter w) +22
       System.Xml.XmlElement.WriteContentTo(XmlWriter w) +29
       System.Xml.XmlElement.WriteTo(XmlWriter w) +145
       System.Xml.XmlDocument.WriteContentTo(XmlWriter xw) +119
       System.Xml.XmlDocument.WriteTo(XmlWriter w) +10
       System.Xml.XmlNode.get_OuterXml() +126
       umbraco.content.CloneXmlDoc(XmlDocument xmlDoc) +52
       umbraco.content.ClearDocumentCache(Int32 documentId) +205
    Any idea?
  • Kyle Skrinak 272 posts 327 karma points
    Nov 24, 2009 @ 14:18
    Kyle Skrinak
    Have you looked at your error log?
