  • Shaun 248 posts 475 karma points
    Nov 24, 2009 @ 20:13
    Shaun
    Ultimate Picker problem
    I'm using V4 and thought I'd try out the Ultimate Picker. I've created a doctype and added the Ultimate Picker to it, giving it the name of "Add Document" and the Alias of "articlePicker".
    However, when I create a new document using that doctype, or when I try to edit an existing document of that doctype, the control itself does not appear.
    I see the element - "Add Document" on the relevant tab. but no control.
    Does something in Umbraco need to be activated before this control can work?
    Nov 24, 2009 @ 20:18
    Shaun
    Ignore me. i've worked it out. The datatype needs to know what parent node it's starting from. Once it has that it works fine.
