  • Phil 3 posts 23 karma points
    Aug 11, 2014 @ 11:16
    Phil
    loop .OrderBy unpublish date
    I've created a simple loop below and I want to order this loop by its umbraco "Unpublish at" property. In my head it should be this :
    @foreach (var example in CurrentPage.Children.OrderBy("expireDate"))
        //Do Stuff//
    This would be similar to Umbracos createDate but isn't working. Anybody got any ideas? Thanks
    Aug 11, 2014 @ 11:22
    Jeroen Breuer
    Have a look at the App_Data\umbraco.config file. There you can see the attribute names of the available data. If there isn't an expire date perhaps it's named something else.
    Jeroen
    Aug 11, 2014 @ 11:31
    Phil
    Thanks for the reply. I see a "createDate" and a "updateDate" but nothing that could be linked to the unpublish date property.
    I'm assuming this means that it is not a standard feature?
    Is there a way around this issue? Other than creating a Date Picker property for the order and then unpublishing them manually?
    Aug 11, 2014 @ 11:33
    Jeroen Breuer
    You could try and find the unpublish date with the content service, but it's not cached so it's not good for performance.
    Jeroen
