Who can tell me which version of TinyMCE is in Umbraco 4.0. I try to wrap text around an image, but I can't find the settings to do so. There is no appearance tab while adding a new image to TinyMCE text area.
I think it's using version 3.x.x of - Don't know if that's specific enough for you?
But if you are trying to place the image in either the left or the right in your text you could define som classes to do so, by adding a stylesheet, which you are can use in the editor.
To do this, you have to create a stylesheet in the "settings" section. Right click the stylesheet and click create. Name your style "left" for instance and make sure your alias is prefixed with a dot so it looks like ".left". Right click your stylesheet to add the right class. The alias names are added to your img tags in the source code, when you name the aliases like shown.
Now you just need to go to the "developer" section and select the datatypes and go to the rich text editor data type and mark the checkbox with the name of your stylesheet.
In the stylesheet you use for your page layout you can add the selectors img.left{float: left;} and img.right{float: right;}
In your content section you now have the possibility add either left or right, to float your image in the text.
I hope it all makes sense and this is what you mean :)
Hi how would you update the spreadsheet tinymce uses.. IE say I want the content administrator to click a button and that renders a div with a certain class.. How can I update teh stylesheet so that what they see in the tiny mce area looks like how it would appear on the live site?
TinyMCE
Kind regards,
Silversurfer
Hi Bas
