  • Jennifer Killingsworth 191 posts 248 karma points
    Aug 20, 2014 @ 16:28
    Configuartion Error
    I'm getting this error whenever I use the backoffice Search in our Umbraco staging instance.  It works just fine in our Umbraco Production instance.  I did a WinMerge comparison and the ExamineSettings.config files are identical.  Everything in the /bin folder is the same.  Any ideas?
    Configuration Error
    Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
    Parser Error Message: There is an error in XML document (0, 0).
    Source Error:
    Line 10:   <ExamineIndexProviders>
    Line 11:     <providers>
    Line 12:       <add name="InternalIndexer" type="UmbracoExamine.LuceneExamineIndexer, UmbracoExamine"
    Line 13:            runAsync="true"
    Line 14:            supportUnpublished="true"
    Source File: C:\hostingspaces\publish.fwc.state.fl.us\config\ExamineSettings.config    Line: 12
    Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1022
