  • Alec Colebrook-Clark 134 posts 258 karma points
    Nov 30, 2009 @ 11:28
    Failure to empty recycle bin
    Hi All,
    This isnt a major issue for us. Basically I created 3 instances of the same umbraco installation (we wanted an installation for each exisiting site, instead of having 3 sites on 1 install) this has gone smoothly and while we had a bit of trouble getting umbraco to pick up that a different site was ordered to be the default home that was solved.
    The issue we have is that one site refuses to empty the recyling bin. When you select it, umbraco hangs. At first i thought it was due to a higher node count, but leaving it didnt remove ANY items.
    Does anyone know why this could be?
    Alec
  • Chris Houston 535 posts 980 karma points MVP admin c-trib
    Nov 30, 2009 @ 12:02
    Chris Houston
    Hi Alec,
    It could be a permissions issue on that installation, if the directory that stores the web service used by the empty recycle bin functionality does not have the right permissions it may well hang, so I'd start by checking your directory permissions.
    Chris
    Nov 30, 2009 @ 13:14
    Thanks for the reply!
    I dont think its a permission issue, I encoutered alot of them when creating the multiple instances so i checked it. Also i forgot to mention that it deleted SOME of the files (after a lengthy "Move to content, delete one item in reclye bin").
    Could it still be a permission issue? If so where should i check? (might be worth mentioning it only happens on one installation)
    thanks
    Alec
  • Nik Wahlberg 639 posts 1237 karma points MVP
    Nov 30, 2009 @ 19:52
    Nik Wahlberg
    I have had this problem on multiple occasions. Please see the following thread for a solution.
    http://our.umbraco.org/forum/using/ui-questions/2787-Empty-recyle-bin-does-not-complete
    Dec 02, 2009 @ 12:37
    Thanks Nik lead to some useful advice
  • Njal 10 posts 31 karma points
    Feb 01, 2011 @ 23:17
    Njal
    I was finally able to empty the recycle bin by removing orphan nodes. See blog for details: http://blog.degree.no/2011/02/problems-with-recycle-bin-in-umbraco-no-document-exists-with-version-00000000-0000-0000-0000-000000000000/
  • Simon Dingley 1474 posts 3431 karma points c-trib
    Mar 28, 2011 @ 12:41
    Simon Dingley
    Thanks for the link Njal, that solution worked for me. Is suspect that maybe the parent node was deleted before the children.
