wait...where should I use it>? I have asp.net mvc background so I understand that this should go to controllers...but I don't have any controllers :/ this is my project (after downloading it)
ok. You can create your views and partials in visual studio that will appear in the admin panel (Back-Office). Except controller and models, only in visual studio. Any questions post here.
Will depend on the structure of your site . You can create a DocumentType for Login and create your content named login. The template for login has this code: @Html.Action("MemberLogin","MemberLoginSurface")
Hi, added a new document and I pased there the line you showed and I'm still getting the error "
No route in the route table matches the supplied values.
Exception Details: System.InvalidOperationException: No route in the route table matches the supplied values.
Source Error:
Line 1: This is member login page
Line 2: @Html.Action("MemberLogin","MemberLoginSurface")
Should I "tell" Umbraco that I created a new controller and he should be aware of it? Or its automatically done?
[HttpPost]
public ActionResult Login(LoginModelView model)
if (Membership.ValidateUser(model.Username, model.Password))
FormsAuthentication.SetAuthCookie(model.Username, true);
var roles = System.Web.Security.Roles.GetRolesForUser();
var cur = UmbracoContext.Security.CurrentUser;
both the roles and cur are null.... (of course the user exists and its validated properly).
Generally what now I want to do:
I will have 2 master pages: A and B.
Page A belongs to Agroup
Page B belongs to Bgroup.
When user logs in, I want to redirect him to the master page that he belongs to, for example the user A, from GroupA redirects to Page A. How can I achieve that?
Second Issue:
In POST of Login funtionality I have this:
[HttpPost]
return RedirectToCurrentUmbracoPage();
TempData["Status"] = "Invalid username or password";
when I'm calling this from view, I have an error saying:
Cannot redirect from a Child Action
Exception Details: System.InvalidOperationException: Cannot redirect from a Child Action
Source Error:
Line 3: Layout = "umbLayout.cshtml";
Line 4: }
Line 5: @Html.Action("Login","AccountSurface")
Redirect after login
how can I redirect user to certain page after the login process is successful ?
Hi Krisek,
WebForms or MVC?
MVC, sorry
Use it in the return of action:
return Redirect("url");
This site has a great example
http://24days.in/umbraco/2012/creating-a-login-form-with-umbraco-mvc-surfacecontroller/
Krisek,
I always create a Controller class in App_Code . In this folder you can create by following the example of 24days site.
Okay, so step by step.
I totally didn't understand this:ple of 24days site what did you meant?
So in App_Code I can create my own controller. thats good, I assume that this controller will inherit from SurfaceController-correct?
So what should I write there to connect my existing Login page?
Or maybe I should create a new one?
I meant the website link.
Yes. Their Controller must inherit the SurfaceController
You can use the helper to create your form in the view or partial . @Html.BeginUmbracoForm<MySurfaceController>(...)
what version of umbraco ?
the latest one which u can download. 7 something i think.
Look, I will go through this website u send me the link and if I step on any problem i will post here :)
I'm not sure: i will add the controller+views +models (through the visual studio) and the will simply come up in the admin panel in web browser?>
regards!
I did as the tutorial was saying, but in my backend I don't see the new View (LoginMember in Partial folder).
Where should I add this: @Html.Action("MemberLogin","MemberLoginSurface") ?
that line of code i put into Master template, then I tried to put it into some other template. I'm getting this error:
then I moved the controller from folder App_Code to "Controllers" (i created that folder) and this is the error:
what is the name of the controller?
you created a partial?
I do not understand why you're calling a @Html.Action.
Please, paste here the code of model , view and controller.
I did this tutorial: http://24days.in/umbraco/2012/creating-a-login-form-with-umbraco-mvc-surfacecontroller/
so the model:
public class MemberLoginModel { public string Username { get; set; } public string Password { get; set; } public bool RememberMe { get; set; } }controller:
using System.Web.Mvc; using System.Web.Security; using Umbraco.Web.Mvc; [PluginController("CLC")] public class MemberLoginSurfaceController : SurfaceController { [HttpGet] [ActionName("MemberLogin")] public ActionResult MemberLoginGet() { return View("MemberLogin", new MemberLoginModel()); } [HttpGet] public ActionResult MemberLogout() { Session.Clear(); FormsAuthentication.SignOut(); return Redirect("/"); } [System.Web.Http.HttpPost] [System.Web.Http.ActionName("MemberLogin")] public ActionResult MemberLoginPost(MemberLoginModel model) { if (Membership.ValidateUser(model.Username, model.Password)) { FormsAuthentication.SetAuthCookie(model.Username, model.RememberMe); return RedirectToCurrentUmbracoPage(); } TempData["Status"] = "Invalid username or password"; return RedirectToCurrentUmbracoPage(); } }Umbraco.Web.Mvc.UmbracoTemplatePage @model MemberLoginModel @{ Layout = "Master.cshtml"; } <hr/> This is the new login page @if (User.Identity.IsAuthenticated) { <p>Logged in: @User.Identity.Name</p> <p>@Html.ActionLink("Log out", "MemberLogout", "MemberLoginSurface")</p> } else { using (Html.BeginUmbracoForm("MemberLogin", "MemberLoginSurface")) { @Html.EditorFor(x => Model) <input type="submit" /> } <p>@TempData["Status"]</p> } <hr/>In the code the return of Action MemberLogin is a type View. Change so.
return PartialView("MemberLogin", new MemberLoginModel());
Okay that looks promising, tell me please where should I call it and how?
for example let's say that I want to create from the backend admin panel a new content site and use it there
Source Error:
Line 2: @Html.Action("MemberLogin","MemberLoginSurface")Should I "tell" Umbraco that I created a new controller and he should be aware of it? Or its automatically done?
I started the project again, from scratch and now its working fine :(
don't know the issue, but thanks for the whole help! :)
There is an alternative which is simpler but works well . You create a script file and use this code https://gist.github.com/joeriks/874194 as a macro.
regards!
Now I have different problem.
1. First of all I did this:
[HttpPost] public ActionResult Login(LoginModelView model) { if (Membership.ValidateUser(model.Username, model.Password)) { FormsAuthentication.SetAuthCookie(model.Username, true); var roles = System.Web.Security.Roles.GetRolesForUser(); var cur = UmbracoContext.Security.CurrentUser;[HttpPost] public ActionResult Login(LoginModelView model) { if (Membership.ValidateUser(model.Username, model.Password)) { FormsAuthentication.SetAuthCookie(model.Username, true); var roles = System.Web.Security.Roles.GetRolesForUser(); var cur = UmbracoContext.Security.CurrentUser; return RedirectToCurrentUmbracoPage(); } TempData["Status"] = "Invalid username or password"; return RedirectToCurrentUmbracoPage(); }Cannot redirect from a Child Action
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.Exception Details: System.InvalidOperationException: Cannot redirect from a Child Action
Source Error:
Line 3: Layout = "umbLayout.cshtml"; Line 4: } Line 5: @Html.Action("Login","AccountSurface")is working on a reply...
