  • Jens Hummelmose 6 posts 26 karma points
    Dec 05, 2009 @ 23:11
    Jens Hummelmose
    Can't get inline XSLT to work
    Hi there.
    I have a media picker field on my document type, and try to get the url from the image.
    When calling the field i get a valid ID
    But when using:
    <umbraco:Item runat="server" field="pSiteBackgroundImage" xslt="umbraco.library:NiceUrl({0})"/>
    It returns nothing.
    I've even reinstalled umbraco to make sure, that it's working.
    Any ideas ?
  • Tommy Poulsen 514 posts 708 karma points
    Dec 05, 2009 @ 23:31
    Tommy Poulsen
    Hi Jens, you can use the GetMedia function - do like this:
    <umbraco:Item runat="server" field="pSiteBackgroundImage" xslt="umbraco.library:GetMedia({0}, 'false')/data [@alias = 'umbracoFile']"/>
    >Tommy
    Dec 05, 2009 @ 23:50
    Jens Hummelmose
    Thanks a mill.. :-)
