I upgraded website from v.6.1.6 to v6.2.3. I try to create macro that alias contains [] and added some parameter, when I inserted macro in TinyMCE it's shown "Alias ' ' does not match an existing macro" by following attached image. I don't want to rename all created macro, any idea thanks!
The reasons because if I rename the macro alias, Although I can add new macros, but for the RTE that has been already added; the macro it will error (shown "No macro content available for WYSIWYG editing").
I've got the same problem on a site which have been upgraded from version 4.11.1 to 6.2.5. Macros with parameters cannot contain [] or any special characters is my conclusion.
Do I need to rename all my 17 macros? And do I also have to update all the content where they are in use now?
Can't insert a marco that alias contains [] in TinyMCE
Why don't you want to rename the macro alias ?
Because that seems to be the solution.
Dave
Hi, Dave
How can it already be added? Your original post is that you can't add it to the rte because of the error you get ?
I added macros on v.6.1.6 before I upgraded to v.6.2.3. The error I post is when I was upgraded.
I've got the same problem on a site which have been upgraded from version 4.11.1 to 6.2.5. Macros with parameters cannot contain [] or any special characters is my conclusion. Do I need to rename all my 17 macros? And do I also have to update all the content where they are in use now?
