OK twitter user's @aim24 and @orcare to the rescue and mentioned its easier to set up the right click mouse button in OSX to the secondary button as opposed to the primary button.
See OSX preference pane for Mouse to change this. Once set to secondary button, it works flawlesy (without need for ctrl + click)
Right Click in RichTextEditor using a Mac
Hiya,
I am looking for help to add right click context menu to the RichTextEditor in Umbraco for Mac users please.
I have found this solution on the tinyMCE forum
http://tinymce.moxiecode.com/punbb/viewtopic.php?id=16484
However if I look inside
umbraco_client/tinymce/plugins/_template/editor_plugin_src.js
This is what the forum post mentions to do:It's easy to fix.
Just do the following in editor_plugin_src.js in context menu plugin: add '|| tinymce.isMac' to the if-statement below.
ed.onContextMenu.add(function(ed, e) {if (!e.ctrlKey) {
I can't find that IF statement in the JavaScript, can anyone please help me out?
Warren
OK im being a bit dumb this morning, I managed to find it (there is anoter file called editor_plugin_src.js in umbraco which contains this code:
This can be found here:
umbraco_client/tinymce3/plugins/contextmenu/editor_plugin_src.js
Updating the src file does not seem to apply the fix, I presume I need to apply in the minified version.
Warren
Screenshot
http://img8.imageshack.us/img8/3935/picture1vof.png
Warren :)
