  • Priya 29 posts 89 karma points
    Oct 17, 2014 @ 12:57
    Priya
    Umbraco V5 - Installation
    I know, this is not the right place to ask this question but I am stuck that's why I ask you guys here.
    My company's website was built in Umbraco V5. And I am very new in my company. somebody deleted the Install folder from the project.
    Now, I have to make some changes in my project how do I make changes ? when I try to run the project, it's giving me the installation error.
    Anybody have any solution for this ?Does anybody have Umbraco V5 installation ?
    Please help me to make my project up and running ?
    Many Thanks.
    Oct 17, 2014 @ 13:23
    Dennis Aaen
    Hi Priyanka and welcome to our.
    What type of changes do you have to make to the site?. Can you please try to explain more. I have tried to describe what changes that you can do outside the Umbraco backend.
    If it to content of the site you should be able to login to the Umbraco backend by this url: http://www.yourdomain.com/umbraco/ after visited that page, you should get a login screen, then you can login if you have a user in the backend for Umbraco.
    If it´s change to templates or XSLT files you can do it on the desk. The files is located as physical files. on your file system. If you need to do changes to document types, add new files or document types or template, and so on you need to be able to login to the backend of your Umbraco installation.
    Hope this helps, and looking forward to hear from you.
    /Dennis
    Oct 17, 2014 @ 13:46
    Priya
    Hi Dennis,
    Thank you very much for your prompt reply.
    As I mention, I am very new to my company, so first of all I have to create new testing enviornment for the website. But when I tried to create new enviornment it gives me installation error.
    Below is the first screen that I am getting.
    When I clicked on Install Umbraco 5.1 , It giving me below error.
    I am able to change in my live website with login into Umbraco backend. But I need to follow the process.
    First I have to make changes in the test enviornment , once it will approved then I am allowed to change in live enviornment.
    My problem is I am not able to create testing enviornment for my website.
    Hope this will help you to anwer me back.
    Again many thank for your reply.
    Priyanka
    Oct 17, 2014 @ 14:26
    Dave Woestenborghs
    Hi Priyanka,
    Can you take a backup of the db and website of your live environment and restore that on your local machine. That should get you up and running with the same Umbraco environment locally.
    But if your still running Umbraco 5 maybe it's time to rebuilt the site in a newer and supported version of Umbraco. Umbraco 5 got cancelled over 2 years ago if I am correct. So it will be hard to find support and help for that.
    Dave
    Oct 17, 2014 @ 14:34
    Dennis Aaen
    Hi Priyanka,
    Okay, I don´t if this could be an option for you. But, one way I see that you could do it, is by taking a backup of the database from your live enviornment, and a copy the files on the system. Then paste in the files to your new testing enviornment, and restore the database from the live enviornment.
    Remember to change the connectionsstring to the database. so it match your new testing enviornment. Then if you creates new document types, templates, XSLT and Razor files in your new testing enviornment, then you can make a package with the new things.
    I have even experienced to synchronize content can be a whole different story if you need that after you have taken a backup of your. If your client are working on the website content on the same time when you are developing new things.
    I have also hear about people who say to the client there are a freeze periode, when they are developing new features, and then if they make some new templates and document types and so on they are created them in all their enviornments.
    Hope this can help you and make sense.
    /Dennis
    Oct 17, 2014 @ 14:35
    Priya
    Hi Dave,
    Thanks Dave for your reply
    I did the same thing. I took the backup of live enviornment and try to replicate on my machine. but as i mentioned in my first post that some one deleted the Install folder from the project :( . that's why I am struglling at the moment. I couldn't find installation on Umbraco's website because they have cancelled V5 over 3 years ago.
    Priyanka
    Oct 17, 2014 @ 14:41
    Priya
    Hi Dennis,
    I did the same thing Dennis, but its not work for me because someone deleted Install folder form the main project.
    Priyanka
    Oct 17, 2014 @ 14:45
    Dave Woestenborghs
    Hi Priyanka,
    Did you also restore your database on a local environment and updated your connectionstring to point to this local database like dennis pointed out ?
    Dave
    Oct 17, 2014 @ 14:47
    Priya
    Hi Dave,
    Yes I did it. I did restore database and changed connectionstring to my local machine.
    Priyanka
    Oct 17, 2014 @ 14:48
    Dave Woestenborghs
    Can you post your web.config to see if see some odd things ?
    Oct 17, 2014 @ 14:49
    Priya
    Hi Dave, Dannise
    I have changed my connectionstring in my webconfig file. Do I need to change anything else in config file ?
    Priyanka
    Oct 17, 2014 @ 14:59
    Dave Woestenborghs
    Hi Priyanka,
    Without a look at your web.config it will be hard to tell.
    But like I pointed out. I would a suggest to rebuild your site to a newer version of Umbraco. This version is not supported and it will be hard to get any support from the community.
    Also time you will invest learning is just wasted time.
    Dave
    Oct 17, 2014 @ 15:06
    Hi Priyanka
    As Dave says above you really should start over using another version of Umbraco since Umbraco 5 got canned due to some serious bugs that affected performance etc.
    It's no longer supported by the HQ nor the community.
    If you're just starting out learning Umbraco by all means please download the latest version of Umbraco 7.1.8 - I'm not even sure where you got hold of version 5 btw? :)
    I don't hope you have based a project on v5 already. If so I think it's worth considering a migration to the latest version instead since continuing will be a waste of time as Dave also points out.
    If it's because you want to do MVC then that should not hold you back since 7.1.8 is running MVC out of the box as well.
    Cheers, Jan
    Oct 17, 2014 @ 15:12
    Priya
    Oct 17, 2014 @ 15:19
    Dave Woestenborghs
    Hi Priyanka,
    I found a github repo with Umbraco 5 site : https://github.com/asapostolov/Umbraco-5-Smallsite/tree/master/Website/Areas/Install
    Maybe you can get the install folder from there.
    Dave
    Oct 17, 2014 @ 15:22
    Priya
    Hi Dave,
    I know its hard to get any support for this version but I have been hired in this company to maintain the website which is aready built. so there is no point ot rebuild the website in latest version.
    Priyanka
    Oct 17, 2014 @ 15:24
    Dave Woestenborghs
    I think you should convince your bosses that a rebuild is needed. There are enough valid reasons for that.
    Dave
    Oct 17, 2014 @ 15:35
    Priya
    Hi Dave,
    I have found the Install folder from that github link.
    But can you please help me how can I copy that folder ?
    https://github.com/asapostolov/Umbraco-5-Smallsite/tree/master/Website/Areas ;
    Priyanka
    Oct 17, 2014 @ 15:40
    Dave Woestenborghs
    On this page you can there is a link to download the code from the repo https://github.com/asapostolov/Umbraco-5-Smallsite
    Dave
    Oct 17, 2014 @ 15:43
    Priya
    Thanks Dave, I will try with this and update you soon.
    Oct 17, 2014 @ 16:14
    Priya
    Hey Dave,
    It's working now ....... Thank you very much  Deve for sending me that link.
    I have copied the Install folder in my project and its run perfectly....
    Thanks every one for your time and quick support.
    Many Thanks,
    Priyanka
    Oct 17, 2014 @ 16:16
    Dave Woestenborghs
    Glad to help you out. Even it's Umbraco 5. Don't forget to mark this post as a solution just in case someone comes along with the same problem.
    Oct 17, 2014 @ 16:20
    Hi Priyanka
    I think that you should tell your boss that you should try to convince the customer go invest in upgrading Umbraco since it's a product that got officially canned by the HQ during CodeGarden 2012 and HQ does no longer support it.
    In the future it can be hard to do new development in the site and extend it - There is also a risk of performance issues revealing themselves at some point.
    And as you already figured out it's going to be really hard to get some proper support regarding a version 5 solution, which means you're perhaps going to spend / waste a lot of time figuring out all kinds of stuff by yourself and in the end your client could end up spending a lot of money on something that does not provide any value to their business.
    I know that it's not necessarily easy to get the message through but I think it's worth giving it a shot.
    Looking forward to hear if you manage to succeed convincing your boss / client about this.
    Cheers, Jan
    Oct 17, 2014 @ 16:25
    Priya
    Hi dev, Jan
    I will mark it as solution.
    And yes i will definatly try to convince my boss to rebuild website in latest version.
    Thanks again for all your support guys.
    Priyanka
