So we want to reload only a partial view that we made through the Umbraco Backoffice.
We only want to reload the partial view so we don't have to reload the whole page again causing a browser refresh.
1. Is this possible? We don't have a control or model, this Partial was build through the Backoffice interface.
2. How would we get the path to the partial view?
3. We are using an external Javascript file (located in Umbraco), but we want to just reload the Partialview.
Carlos,
I have done ajax and partials but within the context of a form submit so
@using (Ajax.BeginForm("SaveReply", "AdminCommentSurface", new AjaxOptions { UpdateTargetId = "formContainer", InsertionMode = InsertionMode.Replace, LoadingElementId = "processing" })) { <div id="formContainer"> @Html.Partial("Admin/VeetReplyForm", Model) </div> }
and in the controller if save is successful i return a different partial with success message. Can you give a bit more information on what you are doing exactly.
Regards
Ismail
Reloading or loading a Partial View using jQuery AJAX
Carlos,
@using (Ajax.BeginForm("SaveReply", "AdminCommentSurface", new AjaxOptions { UpdateTargetId = "formContainer", InsertionMode = InsertionMode.Replace, LoadingElementId = "processing" })) { <div id="formContainer"> @Html.Partial("Admin/VeetReplyForm", Model) </div> }and in the controller if save is successful i return a different partial with success message. Can you give a bit more information on what you are doing exactly.
Regards
Ismail
