  • Lee 1130 posts 3088 karma points
    Dec 09, 2009 @ 18:06
    Lee
    Might Be A Dumb Question...
    I have been following Tims tutorial for the locator package and I post a simple value to a specific page
       <form method="post" action="/shops.aspx">
            <ul class="inlineform">
                <li><input class="bigsearchtextbox" title="Search" type="text" name="s" /></li>
                <li><input class="bigsearchbutton" type="submit" value="GO" /></li>
            </ul>
        </form>
    Now on Tims example, some how his is showing the values posted in the QueryString?
    http://lab.nibble.be/shops.aspx?s=london&radius=100
    But mine doesn't
    http://test.domain.co.uk/shops.aspx
    however everything is exactly the same as its just the default package?  I need mine to show in the QueryString as well, as I am going to have other values to filter the results?
    Am I being stupid, and don't know something obvious?
  • Chad Rosenthal 272 posts 474 karma points
    Dec 09, 2009 @ 18:16
    Chad Rosenthal
    change post to get
  • bob baty-barr 1180 posts 1294 karma points MVP
    Dec 09, 2009 @ 19:46
    bob baty-barr
    if you notice on Tim's example, he has /shops.aspx? as his post url... try adding the question mark to your form post url and see if that works.
    Dec 09, 2009 @ 20:38
    Lee
    @bob - Nope ... Did the same as before but now with a ? at the end  :(
    @Chad - I'll give it a whirl, but Tims example used post?
    Dec 09, 2009 @ 20:40
    Lee
    God damn... Sorry Chad was right :) ... I just checked the source on the online example - Thanks
    Dec 09, 2009 @ 21:56
    bob baty-barr
    that was wierd, i looked at his too and i thought his said post... Get is definitely the answer though... glad it works :)
