  • Craig O'Mahony 364 posts 918 karma points
    Nov 06, 2014 @ 09:42
    Craig O'Mahony
    Loop through children using the ContentService
    Hi folks.
    Could someone tell me if it's possible to loop through all of the children of a node using the ContentService API please?
    For instance what I'm trying to do is loop through every child of a parent node (id 1055) and check it's UpdateDate property.
    Using Nodes I can loop through the node.Children collection but I can't seem to find one for the ContentServive.
    This is what I have to get the Parent Node.
            var contentService = new ContentService();
            var content = contentService.GetById(1055);
            int myDate = Int32.Parse(content.UpdateDate.DayOfYear.ToString());
    But having got this I'd like to loop through the children.
    Could anybody help please?
    thanks,
    Craig
  • jivan thapa 194 posts 681 karma points
    Nov 06, 2014 @ 10:50
    jivan thapa
    What's about this one.
     var contentService = ApplicationContext.Current.Services.ContentService;
        foreach (var childContent in contentService.GetById(1055).Children())
    Nov 06, 2014 @ 11:14
    Craig O'Mahony
    Hi Jivan,
    Thanks but the Umbraco.Core.Models.IContent doesn't contain a definition for 'Children'
    Craig
    Nov 06, 2014 @ 11:27
    Craig O'Mahony
    Sussed it.
            string myString = "";
            var cPages = contentService.GetChildren(1055);
            foreach (var item in cPages)
                //Do stuff in here
    All good!
    Nov 06, 2014 @ 14:26
    jivan thapa
    Anyway, You found the ans.
    There is a def. for "Children", you may missing some stuff. You can compare with this one
