Hi. I just upgraded to a new version of Umbraco (6.2.4), and now this "locked" screen seems to be coming up on the backend all the time. Never seen that before. How can I disable it?
The locked screen comes normally when a user is inactive in 20 minutes, which it the defualt value. You can change this value in the webconfig file, to e.g 1440, whichis a day.
Backend "locked" screen
Hi Chris,
The locked screen comes normally when a user is inactive in 20 minutes, which it the defualt value. You can change this value in the webconfig file, to e.g 1440, which is a day.
<appSettings>
<add key="umbracoTimeOutInMinutes" value="20" />
</appSettings>
Perhaps, it necessary for you to recycle app pool before it takes effect.
Here are some couple of articles about the topic too.
https://offroadcode.com/blog/1500/disable-umbraco-admin-lock/
http://www.codethattalks.com/umbraco-admin-locked-timeout-solution/
Hope this helps,
/Dennis
Thanks! I found that increasing umbracoTimeOutInMinutes fixes the problem.
